Group: DynoMotion Message: 1951 From: bradodarb Date: 10/11/2011
Subject: Secret Console Commands
Hello,
I was looking at how you were issuing feedholds in the KMotionCNC app and I saw some commands in the button handler:
if (TheFrame->KMotionDLL.WriteLineReadLine(board,"GetStopState",response.GetBufferSetLength(MAX_LINE))) return;
response.ReleaseBuffer();
if (response=="0")
TheFrame->KMotionDLL.WriteLine(board,"StopImmediate0");
TheFrame->KMotionDLL.WriteLine(board,"StopImmediate1");
I looked for StopImmediate0 and StopImmediate1 in the script reference but nothing showed up. Did I overloook a bit of documentation?
-Brad Murry
Group: DynoMotion Message: 1954 From: Tom Kerekes Date: 10/12/2011
Subject: Re: Secret Console Commands
Hi Brad,
Yes we need to document those.  The directly reflect the same C functionality described in KMotionDef.h
Hardware Feedhold/Resume was in a state of flux for a while but now it seems to be working well and should be documented.
BTW there is a file in the DSP_KFLOP directory called PC2.c which contains the command parser table that KFLOP uses to parse commands from the PC.  This will always reflect exactly what KFLOP will accept and process.
